Aluminum End Cap with 2 Holes (2″ Series)
$8.00
This aluminum end cap with 2 holes is for use on the 2″ Series Watertight Enclosure.
SKU: WTE2-M-END-CAP-2-HOLE-R1-RP
HS Code: 3923.50.00
This aluminum end cap with 2 x 10mm holes for use with Watertight Enclosure for ROV/AUV (2″ Series).
If you’re looking for a complete set of parts for an enclosure, we highly recommend using the enclosure configurator here.
  • 1 x Aluminum End Cap with 2 x 10mm holes
  • 6 x M2x10 screws
Material6061 or 6063 Aluminum
Surface FinishType 2 Hard Anodizing
Weight in Air41 g 0.09 lb
Depth Rating --
WTE2-M-END-CAP-2-HOLE-R1 (.zip)
28 December 2016
  • R1 – Initial release
Tutorials
Assembly Instructions
Watertight Enclosure Vacuum Testing Tutorial
