Cast Acrylic Tube – 11.75″, 298mm (2″ Series)
$34.00
This optically clear, cast acrylic tube is for use with the 2″ Series Watertight Enclosure.
SKU: WTE2-P-TUBE-12-R1-RP
HS Code: 3917.32.0050
This optically clear, cast acrylic tube is for use with Watertight Enclosure for ROV/AUV (2″ Series).
  • 1 x 2″ Series Cast Acrylic Tube (11.75″, 298mm long)
MaterialClear Cast Acrylic
Length298 mm11.75 in
OD57.15 mm2.25 in
ID50.40 mm2 in
Weight (in air)590 g1.30 lb
Depth Rating100 m330 ft
[Coming soon]
WTE2-P-TUBE-12-R1 (.zip)
8 July 2015
  • R1 – Initial release
Tutorials
Assembly Instructions
Watertight Enclosure Vacuum Testing Tutorial
