Watertight Enclosure for ROV/AUV (3″ Series)
This configurable watertight container is great for use on ROVs, AUVs, and other marine robotics applications. Modular end-caps give you options – dome, flat, and with holes for cable penetrators.
Categories: ,
HS Code: 9014.80.4000
This customizable watertight container is perfect for use on ROVs, AUVs, and other marine vehicles. This enclosure is part of the 3″ Series and has a 3″ inner diameter. A variety of options ensures the right enclosure for your needs.
Features
  • Interchangeable end caps
  • O-ring sealed flanges
  • Cast acrylic tube rated to 150m depth
  • Aluminum tube rated to 500m depth
  • Aluminum end caps rated to 500m depth
  • Dome end cap rated to 900m depth
  • Inner mounting holes on CNC aluminum flange
  • Compatible with our cable penetrators
Diagram
Components
