Aluminum Tube – 11.75″, 298mm (4″ Series)
$180.00
This aluminum tube for the 4″ Series enclosure has an increased 400m (1,312 ft) depth rating and hard anodized finish. Configure a complete enclosure here.
Lead Time: 3-4 weeks
Available on backorder
SKU: WTE4-M-TUBE-12-R1-RP Category:
HS Code: 2005.70.70
This aluminum tube is for use with the Watertight Enclosure for ROV/AUV (4″ Series). It has a significantly increased depth rating compares to the acrylic tube. Note that the inside of the tube is bored out to minimize weight.
Length 11.75 in 298 mm
Minimum Inner Diameter 3.96 in 100.65 mm
Outer Diameter 4.5 in 114 mm
