Aluminum Tube – 8.75″, 222mm (3″ Series)
$120.00
This aluminum tube for the 3″ Series enclosure has an increased 400m (1,312 ft) depth rating and hard anodized finish. Configure a complete enclosure here.
SKU: WTE3-M-TUBE-8P75-R2-RP
HS Code: 2005.70.70
This aluminum tube is for use with Watertight Enclosure for ROV/AUV (3″ Series). It has a significantly increased depth rating compares to the acrylic tube. Note that the inside of the tube is bored out to minimize weight.
  • 1 x 3″ Series Aluminum Tube (8.75″, 222mm)
MaterialAluminum 6061-T6
Surface FinishHard Anodized Black
Weight in Air482 g 1.06 lb
Depth Rating 400 m 1312 ft
WTE3-M-TUBE-8P75-R2 (.zip)
18 April 2017
  • R1 – Initial Release
Tutorials
Assembly Instructions
Watertight Enclosure Vacuum Testing Tutorial
Community
