Extruded Acrylic Tube – 11.75″, 298mm (4″ Series)
$36.00
This is an extruded acrylic tube for use with the 4″ Series Watertight Enclosure rated to 150 meter depth.
SKU: WTE4-P-TUBE-12-R2-RP Category:
HS Code: 3917.32.0050
This extruded acrylic tube is for use with Watertight Enclosure for ROV/AUV (4″ Series). This tube is manufactured with an extrusion process to ensure tight tolerances for O-ring seals. Because of that, the surface is not of optical quality and we do not recommend using a camera to look out the side of this tube. If you are interested in optical clarity, please see our custom length tubes, which are cut from optically clear cast acrylic.
  • 1 x Extruded Acrylic Tube
MaterialExtruded Acrylic
Surface Finish-
Weight in Air768 g 1.69 lb
Depth Rating 150 m 492 ft
WTE4-P-TUBE-R2 (.zip)
18 August 2018
  • R2 – Switched from a casting to an extruding process
13 March 2015
  • R1 – Initial Release
Tutorials
Assembly Instructions
Watertight Enclosure Vacuum Testing Tutorial
