Aluminum End Cap with 5 Holes (8″ Series)
$44.00
This aluminum end cap with 5 holes is for use on the 8″ Series Watertight Enclosure.
In stock (can be backordered)
SKU: WTE8-M-END-CAP-5-HOLE-R1 Categories: ,
HS Code: 3923.50.00
This aluminum end cap with 5 x 10mm holes is for use with Watertight Enclosure for ROV/AUV (8″ Series). We designed these end caps to have a greater depth rating than the clear acrylic end caps. Depth rating to be determined.
  • 1 x Aluminum End Cap with 5 x 10mm holes
  • 12 x M3x12 screws
Holes 5 x 10 mm
Thickness 0.24 in 6 mm
Weight 1.38 lb 626 g
Finish Type 2 Hard Anodizing
