The Ping360 sonar is a mechanical scanning sonar. You can see echoes from objects like ropes, walls, dock pilings, rocks, shipwrecks, boats, and any other structures or objects that reflect sound waves. With that, you have reference points to navigate from, regardless of water visibility, and you can locate important features in the water quickly.
One of the unique features of the Ping360 is the ability to have user configurable communications interface types by changing a few wires around. This guide will show how to configure a Ping360 for USB, RS-485, or Ethernet communications.
Separate the Ping360 Body
To remove the Ping360 body halves, you will need the following tool:
- 1 x M10 Bulkhead Wrench
1. Remove the plastic cord retaining the two body halves together.
2. Using the M10 Bulkhead Wrench, loosen the penetrator just enough so that the air can be equalized.
3. Gently slide the two halves apart. Avoid opening the Ping360 with too much force that the wires are ripped out.
Ping360 Processor Board Overview
The following image shows the different interface port locations:
Processor Board - USB Configuration
Move the 4-pin JST-GH plug to the “USB” configuration port.
Ensure the plug firmly clicks into the receptacle.
Processor Board - RS-485 Configuration
Move the 4-pin JST-GH plug to the “RS485” configuration port.
Processor Board - Ethernet Configuration
Move the 4-pin JST-GH plug to the “ETHERNET” configuration port.
Reassemble Ping360
1. Gently slide the upper head assembly onto the base with the penetrator loose so air can escape.
2. Slide the plastic cord in its channel to hold the two halves together.
2. Using the Bulkhead Wrench, tighten the penetrator so it is “hand tight”.
Wiring Connections - USB Configuration
- 1 x 4-pin JST-GH to 4-pin JST-GH adapter PCB (included with Ping360)
- 1 x 4-pin JST-GH to USB-A adapter (included with Ping360)
1. Connect the power wires (red and black wires) into open screw power terminals (11-25VDC).
2. Plug the JST-GH to JST-GH inline connection board into JST-GH connector coming from the Ping360.
3. Plug the JST-GH to USB-A cable into the other end of the JST-GH to JST-GH inline connection board.
4. Plug the JST-GH to USB cable (USB side) into a computer.
Wiring Connections - RS-485 Configuration
- 1 x 4-pin JST-GH to male header pin adapter cable (included with Ping360)
- 1 x 4-pin JST-GH to female header pin adapter or 2 x 0.1″ male-female jumper wires (not included)
3. Plug the 4-pin JST-GH to male header pin adapter into the JST-GH to JST-GH inline connection board.
4. Plug the male header pin adapter into an unused twisted wire pair on the tether.
5. Plug a 4-pin JST-GH to female header pin adapter or 2x 0.1″ male-female jumper wires into the corresponding unused twisted wire pair coming from the FXTI tether pigtail.
6. Plug a 4-pin JST-GH to female header pin adapter or 2x 0.1″ male-female jumper wires into the RS-485 TX/RX pins on the RS485 side of the BLUART.
7. Plug the BLUART into a computer using a Micro-USB to USB-A cable.
Wiring Connections - Ethernet Configuration
- 1 x Ethernet Cable (not included)
2. Plug the JST-GH connector coming from the Ping360 into the JST-GH connector on the RJ45 to JST-GH Adapter Board.
3. Plug an Ethernet cable into the RJ45 jack on the RJ45 to JST-GH Adapter Board.
4. Connect the other end of the Ethernet cable to a router or your computer.
Configure Network Settings
1. Make sure you are using Ping Viewer version 2.4.1 or newer. Configure the Ping360 Network settings from the Ping Viewer device manager screen.
- The Ping360 is configured as a DHCP client by default and will be assigned an IP address automatically when connected to a DHCP server such as a router.
- The IP address can also be configured manually by opening the network configuration menu and selecting “Static IP”. Enter an IP address that is on the same subnet as the computer you are trying to connect from.
Example: If your topside computer’s IP address is 192.168.2.1 with a subnet mask of 255.255.255.0, the IP address used for the Ping360 should be 192.168.2.X (e.g. 192.168.2.4).
USB Configuration
1. Ensure the power and data wires are correctly plugged into their respective ports (POWER, USB) on the Ping360 processor board.
2. Ensure the power wires are correctly installed (positive and negative) into the power source. Ping360 does not have any reverse polarity protection and the Processor Board will be damaged if powered incorrectly.
3. Ensure the JST-GH connectors are plugged firmly into their receptacles. There will be a mechanical “click”.
4. Check to make sure you have the most recent stable release of Ping Viewer.
5. Contact [email protected] for further troubleshooting recommendations.
RS485 Configuration
1. Ensure the power and data wires are correctly plugged into their respective ports (POWER, RS485) on the Ping360 processor board.
4. Try reversing one of the header pin connectors.
5. Check to make sure you have the most recent stable release of Ping Viewer.
6. Contact [email protected] for further troubleshooting recommendations.
1. Ensure the power and data wires are correctly plugged into their respective ports (POWER, ETHERNET) on the Ping360 processor board.
5. Check to make sure the Ping360 network settings have been configured correctly in Ping Viewer.
6. If you have a firewall enabled, create an exception rule to allow Ping Viewer through the firewall.
7. Contact [email protected] for further troubleshooting recommendations.
